メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
250GB HDDとWi-Fiを内蔵したXbox 360のスリム版も出る。修理には複雑なこじ開け作業と特殊な工具が必要です。
How can I fix error code 0020?
Purchased an xbox 360 s from ebay for about 20$, description said it had a RROD but didn't elaborate. When it arrived I checked the error code and it gives me 0020.
Warranty sticker looked like it was half peeled off, so someone for sure tried fixing it before. When it turns on, the power supply light turns green, does that narrow the culprit down at all?
From the research I did there isn't one single reason for the code. What should I do first? Is it worth trying to fix?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
@twigg37531 "this secondary error code is caused by the GPU reset communication. If this test is not completed successfully on boot up, you will get this 0020 error code on the Xbox 360 console. This can be caused by TONS of components as there are multiple areas that manage this info, and could be bad." Check for more about that on here as well as on here Most common issue will be the GPU. A reflow might fix this. Going to be a tricky one but for $20 you got nothing to lose. Go ahead, give it a try and let us know how it worked out.
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
Reflowed GPU, still gives the same error code. Anything else I can try or is it just not worth it?
さんによる
コメントを追加
回答を追加する
Twigg さん、ありがとうございました!
統計データ:
過去 24時間: 9
過去 7 日: 31
過去 30 日: 116
今までの合計 1,159
