Why is my Vizio D32 TV displaying double images?
My Vizio D32 TV started showing ghosts-like double images for the last couple of days. I've tried factory resetting it and it still occurring.
@bovilewis we would have to see more of what this looks like. Common cause for double vision is a failed T-con board as well as a bad LCD panel (LCD driver boards) but that is to a lesser extend. I would start with the T-Con board. Of course, you always want to check the ribbon cables as well. Make sure those are properly seated and are in good shape. No tears or corrosion on the contact is a minimum.
Next post some pictures of what your display shows as well as your boards. That way we can see what you see and hopefully guide you further, if needed.
このアンサーは役に立ちましたか?
過去 24時間: 1
過去 7 日: 4
過去 30 日: 10
今までの合計 18
