メインコンテンツにスキップ
任天堂スイッチは、ドッキングステーションを介してテレビで遊んだり、外出先で遊んだりできる携帯型ゲーム機です。2017年3月3日に発売されました。
LCD connector stripped traces
I successfully desoldered the LCD connector, but unfortunately when I was wicking the factory solder to tin the pads, I rubbed off some of the solder mask. Does anyone have advice or a diagram I can use to make sure all the traces still work? It would also help since I think I need to run jumper wires on the scratched off parts. The first 2 images are the before, the next 2 are the aftermath.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
ベストアンサー
I’ve got a board and I’m trying to find the traces for you. I’m not done yet but I’ve got somewhere for you to start at least. According to my testing all these pins should be connected to ground.
Hope that helps. I’ll keep looking for the other pins but it’ll take time. I’ll get back to you when I get more info.
Have a great day!
Edit:
Here’s some of the pins. These are the ones that are on this side of the board. Working on the others still.
このアンサーは役に立ちましたか?
スコア 1
6 件のコメント:
Thank you so much! If solder is sticking to the exposed parts I scratched off, does that mean the copper is still there and I do not have to fix the traces?
さんによる
Yeah most likely they’ll be fine. Sorry I haven’t gotten back to you with the other pins but I’m working on it. Hopefully I’ll get back to you later tonight or possibly tomorrow with the rest.
さんによる
@albertg87002 I see. Thank you so much. Do not fret as I am in no rush and you're doing this out of the goodness of your heart
さんによる
Ok, I’ve gotten done some of the pins. I’ll update my original post with the picture. All the pins/pads of the same color should have continuity between each other. Unfortunately the other pins are more difficult to trace because they go through the board, but I’ll figure it out and update you when I do.
さんによる
With your outlines, it appears that I just scraped off the solder mask and none of the connections were damaged. Thank you so much for the help!
さんによる
1以上のコメントを表示
コメントを追加
回答を追加する
Will さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 10
過去 30 日: 35
今までの合計 344
