My fingerprint sensor is not working
Fingerprint sensor not working, The test said: CALI test result: false. What happened to it?
Have you replaced the display?
According to reddit you'll need to recalibrate the sensor if you have.
I'd also recommend cleaning the scanning area with a Microfiber cloth to ensure accurate reading.
"To access the calibration menu you need to:
Go to settings > About phone > All specs > repeatedly tap Kernel version until the calibration menu appears > tap the menu button in the top-right corner > Additional tools > 6. Fod fingerprint calibration.
Follow the steps on the screen. The first test is to hold a white cloth/paper over the fingerprint sensor. The second test is a black cloth/paper. The third test, just use your bare finger.
If it says "Test successful" at the end, the fingerprint sensor should be ready to use. If the test fails, try again. I read a forum post where someone had to try three or four times before it passed."
If recalibration doesn't fix the issue I'd recommend a visual inspection of the internal hardware.
このアンサーは役に立ちましたか?
過去 24時間: 1
過去 7 日: 22
過去 30 日: 123
今までの合計 241
