Why is my laptop not turning on
My lapotop is not working it's not turning on what should I do
Well I will suggest you to check out the following thread: https://answers.microsoft.com/en-us/wind...
このアンサーは役に立ちましたか?
Does the charging indicator light up when you're charging? If it does, press the power button, then press the capslock and numlock check if they light up. If they do, you may have a problem with the screen.
(Use a USB keyboard, if available, can make it easier to spot the LED indicators)
このアンサーは役に立ちましたか?
過去 24時間: 1
過去 7 日: 6
過去 30 日: 29
今までの合計 29
1件のコメント
I don't know
Hamza Mearuf さんによる
