Where can I buy the uploader valve
where can i buy the uploader valve
@wilmeister37410 if you are referring to the unloader valve by the pump, that is part number 310924003
It is widely available since it has been used in many different pressure washers. Available from Amazon to Walmart.
このアンサーは役に立ちましたか?
this is what the cs told me after 5 hours on hold talking to 4 people. he 1st tried to say that i had to buy the whole pump. but ended up verifying the number
the whole problem is they do not have the uploader valve on the parts diagram therefore there is no part number to verify t
he correct fitting of the unloader valves i found
過去 24時間: 0
過去 7 日: 0
過去 30 日: 12
今までの合計 36
