メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
2022年10月に発売されたGoogleのスマートフォン、Pixel 7 Proの修理および分解情報。モデル番号GP4BCおよびGE2AEで識別可能。
Where can I buy a replacement LCD display bracket?
I've had to replace my pixel 7 pro screen a few times. The bracket that holds the LCD display flex ribbon snapped, and would like to get a new one before I replace the LCD. Any idea where I can purchase one?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 3
1件のコメント
Anyone have any luck finding one of these in stock?
さんによる
コメントを追加
4件の回答
最も参考になった回答
Hi Michael,
I'm assuming @betatechlabs is pointing in the wrong direction; my impression from reading your question is that you're looking for the metal retainer that keeps the display flex cable from being jarred loose in the case of being dropped; i.e., the one in this picture.
画像
I poked around quite a few obscure corners of the internet, but I'm afraid I didn't have any more luck than you in locating one for sale.
このアンサーは役に立ちましたか?
スコア 2
3 件のコメント:
Where can I get one of these
さんによる
I was able to find one on AliExpress via google search
The link is huge, So I will paste the name of the product.
Basonlif LCD Flex Cable Bracket Holder Stand For Google Pixel 7 7Pro Pro Replacement Part
$10 after shipment.
I think "I fixit" should include that Clip in the kit.
My Screen Stopped working, so I thought to replace it, removed the screen, and the Pin was missing. The people who fixed my phone last time must not have put the pin back in... Attached the connection, and the screen is working again. I still need the pin. $10 is a little too much just for the pin, so I will see how long my screen will last.
さんによる
@tlgwegg iFixit gets their Pixel replacement parts directly from Google, so they can only supply what they get, unless you think they should sell a mix of OEM and aftermarket parts when they're supplying their Pixel parts as genuine Google parts.
For some reason AliExpress adds a lot of crap to their URLs, but I've found you can almost always trim everything after the .html part. Here's the one you mentioned.
https://www.aliexpress.us/item/325680905...
さんによる
コメントを追加
@michaelnun25749 looks to me like you are referring to these brackets
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
Excellent find, my friend! That listing also gives us the clue that the same bracket appears to be used in both the Pixel 7 and the Pixel 7 Pro.
さんによる
コメントを追加
For what it's worth, I have two (technically 3) Pixel 7 Pro's for my wife and I that I perpetually cycle through new screens every few months when one of us drops one or they take a plunge. Since almost every time I open one means a screen replacement (superb build quality), I've had the display cable holder brackets on and off enough times that two have broken so far. I ordered the Pixel 8 display bracket holder iFixit sells with fingers crossed, but it was too small. And I can confidently say a piece of cardboard rolled only lasted a week.
All that to say, I tracked down a supplier, but they're not cheap. They were out of stock everywhere else in the US and on Aliexpress.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
What's good Michael? You can buy a replacement LCD display bracket, also known as a front LCD screen bezel frame or LCD frame holder, for your Pixel 7 Pro online from various retailers.
Things to consider when buying a replacement LCD display bracket:
  • Make sure the bracket is compatible with your specific Pixel 7 Pro model. There may be slight variations between models.
  • Consider the condition of the bracket. Some listings may be for used brackets, while others are for new ones.
  • Read the reviews before you buy. This can help you get a sense of the quality of the product and the seller's reputation.
Additional tips:
Replacing the LCD display bracket on a phone can be tricky and requires some technical skill. If you're not comfortable doing it yourself, you may want to take your phone to a professional repair shop.
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
Hey BTL,
Thanks for your reply! The bracket I'm referring to is not a front bezel bracket. Before you connect/remove the LCD ribbon from the mother board, you have to remove a bracket that holds the ribbon in place. It's a small, half an inch piece. Here's a link as an example: https://www.aliexpress.us/item/325680494...
I'd rather buy this piece from another place. It's also out of stock on AliExpress.
さんによる
Ah I see. Thanks for the feedback!
さんによる
コメントを追加
回答を追加する
Michael Nunez (GoogleMike) さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 10
過去 30 日: 54
今までの合計 1,706
