My call cut automatically and says server is unreachable
My phone call is cut automatically and says server unreachable
You might be using Wi-Fi calling, check in your phone's settings if Wi-Fi calling or "VoIP" is enabled and turn it off, you can also try to make the same call while not connected to Wi-Fi.
this feature lets to route calls over Wi-Fi to improve calls in areas with weak phone signal, but not all phone networks support this fully, and it might not work on some Wi-Fi networks.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 144
