Engine kills when engaged
Engine runs when engaged it kills the engine. There is no binding of the belt.
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Loubie,
Sounds to me like the engine does not like to run under load.
If you have a local fixit man, go get a good tuneup for the season. If you do not have a local fixit wizard, try to buy and install your own carb rebuilder kit. There are probably several you-tube tutorials on your specific mower or engine or carburetor. However do not worry, as a lot of the small carbs have similar components and operate the same basic way. Additionally, do not worry if you have extra parts in your rebuild kit as some kits are sold generically and contain parts that may fit in a great number of carbs.
Gasoline these days contains ethanol, which gums up carburetors as they sit in the off season. Sometimes chemicals such as "Stabil" help to alleviate this but not always. A lot depends on how long it sit and how much fuel is in the tank and the carb. Change the fuel in your tank also to fresh fuel.
Hope all that helps,
Frank
このアンサーは役に立ちましたか?
過去 24時間: 1
過去 7 日: 1
過去 30 日: 10
今までの合計 411
2 件のコメント
Loubie, what mower is it and what have you tried so far to fix it?
oldturkey03 さんによる
Check your safety switched with a multimeter and make sure that they are working right, especially the seat switch. If functions as a killswitch.
oldturkey03 さんによる
