メインコンテンツにスキップ
Repair guides for cell phones branded under the Microsoft Lumia name sold from November 2014 to early 2016. Lumia phones were also sold under the Nokia brand before 2014.
Microsoft Lumia 430 not charging and not turning on
microsoft lumia 430 not charge and not turn on
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
2 件のコメント
Hi @manjunathamanju
Have you tried using a different, known working, compatible charger or charger cable to see if the phone will charge and also turn on, you didn't say?
さんによる
@jayeff Phone won't turn on and won't charge when using a different charger, cable
さんによる
コメントを追加
2件の回答
最も参考になった回答
Did you try a different battery? A battery that is removed or nonfunctional, as I have experimented with my Lumia, would cause the problem of a nonfunctional phone.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
Hi @manjunathamanju
Use a strong light and a magnifying glass and visually inspect the phone's charge port enclosure, to make sure that there's no lint etc, in the port enclosure, that may be preventing a good electrical connection between the charge cable plug and the pins in the port. Also make sure that all the pins (5) are there and that they're all straight and parallel with each other and not that they're bent or even missing.
If there is debris in the port enclosure, do not use a metal pin or probe to try and clear it. Try using a vacuum cleaner instead and check if that clears it. If still no good, use a wooden toothpick to gently clear any debris from the port.
If the port seems clear, try the following to determine if the USB port connector is loose from the systemboard. Insert the charger cable into the phone's USB port only, do not connect the other end of the charge cable to anything!
Then take a firm hold of the phone in one hand and with the other hand grab hold of the charge cable plug which is inserted in the phone and gently, stress gently, try moving the plug up and down and side to side and check if you can feel any movement at all in the port, indicating that it may be loose.
If there's no movement or even if there is then the phone will have to be opened so that a) if there is movement, the USB connector can be resoldered back onto the systemboard or b) if there is no movement, that the phone 's power input circuit can be checked using the schematics in the service manual. Start on p.29 (of 39) in the manual
Here's a video that shows how to disassemble the phone that may also help.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Manjunatha Manju さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 4
過去 30 日: 18
今までの合計 203
