メインコンテンツにスキップ
2019年11月4日に発売されたXbox One Elite Wireless Series 2コントローラーは、Xbox One、X、&Sコンソールのほか、Windows 10/11を搭載したPCに対応します。
40回答 すべてを表示
Changed battery for OEM, still no power?
Hi, I'm having an issue with getting this Series 2 Controller to turn on. I ordered a replacement OEM battery from Microsoft and replaced it myself.
When I seat the boards back onto the bottom half of the controller it turns on and acts normal for about 10 seconds, then it proceeds to shut off. No buttons can turn it back on and when I plug it in via USB or seat it on its docking station it sits unresponsive with no lights.
When I plug the boards into the USB without seating it on the back half with the battery's it works fine and stays on. There seems to be an issue when seated to the battery.
Has anyone else had this issue or know of possible causes?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
Hi Ashton!
My guess is that this didn't happened with the old battery, right?
It just sounds like that the replacement battery is faulty. Return it and ask for a new one OR get a refund.
このアンサーは役に立ちましたか?
スコア 1
2 件のコメント:
Sorry, yes this was happening with the old one which is why I replaced it. I'm starting to suspect it's the I/O board and may think the battery is overheating?
さんによる
No problem! Well that changes it! It could be the I/O board or the motherboard. (my guess it's the I/O board causing this). You can buy the parts here: https://www.aliexpress.us/item/325680306...
さんによる
コメントを追加
回答を追加する
Ashton さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 4
今までの合計 46
