Why is my loaptop not charging
But it is in good condition
Did you drop it or anything?
Check the charging port (the part where you stick the power chord into) for any dirt, debris, or anything else that would hinder the charging port from going all the way into the charging port
Try a diffrent charging port(if you computer has multiple), a diffrent charging cable, or even a diffrent outlet
このアンサーは役に立ちましたか?
過去 24時間: 1
過去 7 日: 6
過去 30 日: 12
今までの合計 179
While connecting the Charger It Will Running Perfectly
But The Problem Was When I removed the charger it will Power off immediately with in seconds
Acer extensa さんによる
@acerextensa have you replaced the battery yet? If not then you definitely want to start with that.
oldturkey03 さんによる
