メインコンテンツにスキップ
New Nitendo 3DS XLは2014年10月11日に発売されたNintendo 3DS LLの後継モデルとして、日本国内で発売されました。北米では、2015年2月に発売されました。
20回答 すべてを表示
My Nintendo 3ds xl (2015 model) has both screens completly black
My 3DS XL (2015 model) will show the blue light for power, but both of the screens are black. This happened in 2019, and I got it in 2016. I have been trying to fix it for months now, and even tips from @darthmango have not helped. I just want to know if there are any other ways to fix it, or if I should get it repaired. Please help @darthmango, Im losing hope :(
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
14 件のコメント
Hi!
First thing first, What is tried already and what did @darthmango tried? I know that even sometimes the MicroSD card reader can give issues like this, there is no MicroSD card inside, right? If yes, then remove it and try again. Just let us know what is tried, so we can help you further! Thanks in advance!
さんによる
@dan0 Everything. Safe mode, SD removal, everything. I cant do much bc I am 14, but I have tried everything I can. Do you have any other ways to help?
さんによる
Is the console modded? Anyway, I'm afraid that this is motherboard related... Probably the Nintendo CPU or the Samsung NAND. My guess is that you only can fix it with a new motherboard. They are for sale here: https://www.aliexpress.us/item/325680671...
Not sure if you can fix it by yourself? Otherwise you can bring it to a local repair shop and ask them to fix it for you.
さんによる
@dan0 It is not modded. I hoped not to resort to that option, because I know that repairs for the 3ds nowadays are shady, but I will try my best. Thank you all for the support :D
さんによる
@jahasend Alright, then it must be something motherboard related. Sry for the bad news :(. Hopefully you will get it repaired asap again! My pleasure, here to help :)!!
さんによる
9件以上のコメントを表示
コメントを追加
2件の回答
最も参考になった回答
Hi Jahasen, A few things could be wrong with your Nintendo 3DS XL that's causing both screens to go black:
  • Loose or Faulty Connection: The ribbon cables that connect the screens to the motherboard might be loose or damaged. These cables are fragile and can wear out over time.
  • Faulty Screen: It's possible that one or both of the screens themselves have malfunctioned.
  • Motherboard Issue: As @dan0 said, the problem could lie with the motherboard itself.
Here are some steps you can try:
  • Soft Reset: Try a soft reset by holding the power button for 10 seconds. This can sometimes clear up minor glitches.
  • Clean the Connector: If you're comfortable opening the 3DS, you can try carefully cleaning the connectors on the ribbon cables with isopropyl alcohol (50-90%).
However, if you're not comfortable opening the device yourself, it's best to take it to a professional for repair. They will be able to diagnose the problem and fix it for you.
このアンサーは役に立ちましたか?
スコア 3
コメントを追加
@jahasend ok, look i found some videos, this one is easy, trust me,
https://www.youtube.com/watch?v=EY-Cupq3...
hope you can do this :D @jahasend infact im 10000% SURE its this. please do it. if you TRUELY care for it and is careful, then ur perfect try it ;)
all you have to do is unscrew some screws (USE THE PHLLIPS #0 OR #1 SCREW!) then once you open it, just, all you need to do, just remove some ribbin cables like the wifi thing and yea! and PUT IT BACK IN AND MAKE IT TIGHT, VERY TIGHT and make sure it not put to much perssure tho! and uh yea thats it and turn it on after putting everything back!
このアンサーは役に立ちましたか?
スコア 0
5 件のコメント:
@jahasend HELLO ANSWER RQ
さんによる
Bro my fault I was on vacation and I have been watching the videos I'm just waiting on the tools, but thanks a lot!
さんによる
@jahasend on cool man, sounds great!!!
さんによる
@jahasend any updates so far?
さんによる
@jahasend DID IT BREAK?!??!?!?
さんによる
コメントを追加
回答を追加する
Jahasen :D さん、ありがとうございました!
統計データ:
過去 24時間: 3
過去 7 日: 16
過去 30 日: 37
今までの合計 167
