メインコンテンツにスキップ
モデル番号はA1706 / EMC 3071ー2017年6月発売。この13インチMacBook ProはKaby Lakeプロセッサが搭載されています。最大4.0 GHzのTurbo Boost付き3.5 GHz Core i7です。
Broke some components while attempting battery swap
Broke some components located on the left side of the logic board (with the touchpad facing towards you) while replacing battery on my MacBook Pro 2017 With Touch Bar A1706. Please help me identify the components and their purpose so i can get them repaired. Kindly see attached photos.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
ベストアンサー
This doesn't look like a tremendous amount of damage and it's quite common for these to get nudged during the course of repair.
The chip is a temperature sensor intended to monitor air flow temperatures on the right side of the board and the right side thunderbolt controller. It looks like there are a few traces pulled up from the circuit board, which will specifically need repair.
For reference it is a Texas Instruments TMP461 if you want any of the specifics, but I don't see any damage to the chip, so it's likely to be perfectly fine.
This probably won't affect the ability for your Mac to power on, but it might run very very slow, since this temp sensor is unlikely to work properly in its current state.
Otherwise, it looks like a capacitor got nudged. This is part of the power circuit for the built in SSD. There are many other capacitors on this same line, so its presence is not 100% needed, but it's along the edge and would be easy to replace. The schematics call for a 22 µF 10V capacitor in a 0603 package.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
回答を追加する
Waleed Pahe さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 8
今までの合計 110
