How can we change the charging base A13
How can we change the charging base of A13
@abozarwolasmal since iFixit does not yet have a guide for that specific task, use the guide from here It was written in Spanish so you'll need to use a browser that does the translation for you, if it is needed.. Replacement charging boards are readily available at many online stores. Make sure you get the right one for your model
While you work on your phone, take lots of pictures. Once you are done with it, take those pictures and create a guide for iFixit. That will help the next person that has a device with the same issues as you do. It's easy and fun to create these guides. https://ifixit.com/Guide/new The iFixit community will appreciate this.
Repair is War on Entropy!
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 8
今までの合計 8
