メインコンテンツにスキップ
OnePlus 5(OP5)は、2017年6月20日に発売された第5世代スマートフォン。OnePlus 3Tの後継機種であり、OnePlus 5Tの前モデルである。
Touch died one day after battery replacement
I replaced the battery myself, folowing the guide on the oneplus 5 here. Everything went well and worked when i was done. I am 100% shure the touch worked after i was done. I left the phone charging over night to start the battery calibration. When i checked the phone the next day the touch wasn't working at all, no reaction, nothing, not in the OS or in the recovery screen. It seems like damage from the battery replacement but i find it strange that it only stoped working a day after. I reopend the phone to checked and reseat the connectors that need to be unpluged for the battery replacement, no change. I updated the OS and reset to factory settings wich also didn't help (i use LineageOS). Any ideas on how to fix this or what the problem even is?
additional info:
-I used 70% isopropyl alcohol on the battery to remove it, i was carefull to remove all fluid i could see afterwards -could it be water damage?
-the screws for the speaker got mixed up on reassembly -are they not all the same lenght?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
ベストアンサー
The fix seems to be to clear the system cache from the recovery mode.
When i searched online for solutions, it seems like the OnePlus 5 had problems with the touchscreen somewhat often.
This fix was one of the suggested solutions.
Good to know my screen isn't broken.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Dorian さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 4
今までの合計 45
