メインコンテンツにスキップ
The Lenovo ThinkPad X1 Carbon 10th Gen is a high-end business laptop produced by Lenovo, a Chinese multinational technology company. It was first released in 2020.
2回答 すべてを表示
“Fan error” upon startup. One of the fans doesn’t spin. How to fix?
One of the fans on the underside doesn’t spin, even when I blow air on it. The other does.
How can I fix it without disassembly? I don’t want to void the warranty or mess up and break it.
Currently running in backup mode so would appreciate any help!
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
@patquinlan you can't. You will have to disassemble it and replace the fan. If you do consider working on it, use the Lenovo X1 Carbon Gen10 Hardware Maintenance Manual to help you with that. Page 71 tells you what to do. Now, if your computer is still under warranty ("I don’t want to void the warranty") notify the seller and have them fix it. Ultimately somebody will have to fix it since it will eventually overheat and that will just cost you more money and time.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Pat Quinlan さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 22
今までの合計 22
