メインコンテンツにスキップ
Microsoft社の第3世代ノートパソコン Surfaceの15インチモデル用修理ガイドと分解情報です。
10回答 すべてを表示
laptop doesn't turn on, no charging light too, what could be wrong?
Had this laptop for a while, but noticed recently that it doesn't turn on any more, and no charging light either when connected with charger. Is there an easy way to check if it is due to failure of mother board or any other components?
Thanks,
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
最も参考になった回答
Hi Tom, did this just happen out of the blue? Please elaborate on what you were doing before this happened.
Update (04/29/24)
Interesting, In that case I would advise the following:
1. First, try to unplug the CMOS battery and then put it back in to reset the BIOS. If this doesn't work, then it's likely a fault with the motherboard or the bios.
DISCLAIMER: Before you do these, check out what others around here have to say, as many know more than I do.
2. Try to make some measurements with a multimeter to identify any shorts. I would advise you to attempt to use a thermal camera if you have one around. If you don't then there's always apps for mobile devices of all kind to compensate for that! Once you identify what part is shorting the board out, let me know and we can proceed from there.
3. This is less likely, albeit a little (somewhat) simpler. Your BIOS chip could be very well corrupted, and in that case you'd need to write a new BIOS to it. This can be done Via a bios reader. Once you have that, you will need to backup the contents just in case, then write a new bios to it. Once done you should be fine to reinstall the chip.
このアンサーは役に立ちましたか?
スコア 1
3 件のコメント:
@ArandomHitman, I didn't use it for some time, and just noticed it when I try to turn it on. Any thoughts?
さんによる
@oldturkey03 I can't seem to do it atm, ill try to figure it out later.
さんによる
@arandomhitman taken care off.
さんによる
コメントを追加
@lovecd I'd start with the basics. First you want to check your power supply. Make sure it has the proper voltages. Check to make sure that connectors are not bend etc. Check the DC-in jack of your laptop. Make sure there is no corrosion, debris etc. that prevents it from working. Clean it of any debris etc, use a few puffs of air to clean it out.
If none of this works, get an ammeter and see if your laptop draws any amperage from the charger. After that, you need to check and see if your motherboard even gets power. For that of course, you need to open it up. Use these guides Microsoft Surface Laptop 3 (15-inch) to work on it.
This "I didn't use it for some time" is a pretty good indicator that teh battery has discharged below its charging threshold and it will not accept a charge. It is "locked" There is a way to deal with that but it's costly. I'd consider replacing the battery for sure.
Post Some good pictures of what you see. That way we can see what you see
iFixitでの質問に画像を追加する方法
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
I opened the cover, it physically looks fine, please see pictures I added. Any thoughts?
さんによる
コメントを追加
回答を追加する
Tom さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 52
今までの合計 52
