Where is the transmission fluid located?
Where do you put transmission fluid?
The transmission fluid is stored inside your car's transmission, but you can't directly access it there. To check the fluid level, you'll need to locate the transmission fluid dipstick.
This dipstick is usually found under the hood of your car and resembles the engine oil dipstick. The exact location can vary depending on your car's make and model:
If you're unsure where to find it, consult your car's owner's manual for specific instructions. They will also detail the process of checking the transmission fluid level and topping it up if needed.
And is one of those few things that we don't change in modern cars.
このアンサーは役に立ちましたか?
Probably not helping here with your AI generated information, since most VW transmissions are considered sealed units and do not have a dipstick. In addition, Doreen wasn't asking about checking the fluid level, but rather wanting to know where to add fluid.
We'll have to wait for her to give us more information about the specifics of her vehicle, but it's a fairly safe bet that determining the fluid level is far more involved than just checking a dipstick. I know on my New Beetle it's a nightmare with a whole sequence of requirements to be met; level ground, a specific temperature, etc.
AI is really not impressing me at all. Only good thing I can say is, it looks pretty and great spelling. Content is extremely weak and not helpful for any question. Just some mediocre technobabble, regurgitated stuff it finds under Google and Bing.
過去 24時間: 2
過去 7 日: 11
過去 30 日: 45
今までの合計 45
Hey there Doreen, which year of Tiguan?
Jacob Mehnert さんによる
Well “Tiguan” and “transmission” is hardly specific at all, what region, what year and what trim it is, different productions may use different transmissions.
If it’s a DCT it could have two separate pockets of transmission fluids, otherwise it’s just one.
Tom Chai さんによる
