It keeps turning off and on by itself.
Hello, for some reasons my acer chromebook keeps turning off and on, thought it was the battery, plugged in the charger it still did the same thing.
I went on youtube, saw a video with similar problem, his solutions were:
Tightening the screws.
Did that worked for some weeks then it started again.
この質問は役に立ちましたか?
15 件のコメント
@maxwellimoh tighten what screws :-) ?
oldturkey03 さんによる
@oldturkey03 All and any screw you see in and out of the chromebook.
Maxwell Imoh さんによる
@maxwellimoh that sounds like an interesting fix ;-) Tell us how it "keeps turning off and on" exactly. What does it do? What does your Power LED show?
oldturkey03 さんによる
@oldturkey03 Whenever I turn it on, sometimes before I type in my password or even begin anything it turns off.
After it turns off, if I close the lead, few seconds or minutes later it turns back on, then later it turns back off.
My Power Led: At first I thought it was the battery but when I plugged in my charger it was charging normal.
But if I turn it ON even with the charger plugged in, it does the same it.
N.B this occured for complete two weeks untill I decided to disconnect the battery.
I JUST REMEMBERED:
I powerwashed my chromebook more than two times because of the issue.
Maxwell Imoh さんによる
@maxwellimoh for now I am not quite convinced that this is a power off situation. Start it up and try to run it through the startup. Once it turns off, darken the room and get a flashlight. Now shine the flashlight at an angle against the screen. See if you can still make out the desktop etc.
oldturkey03 さんによる
10件以上のコメントを表示
