Xbox series s turns off 2 seconds after I turn it on?
Why does my xbox series s turn off about two seconds after I turn it on with no display I think it could be the ssd do I need to buy a new on if so were do I get the xbox os from.
It seems like your Xbox Series S might be shutting down due to an issue with its SSD. Try these steps:
If the issue persists, you may need to replace the SSD.
このアンサーは役に立ちましたか?
@tabathakang AI, got a question for you. How do you suggest to perform factory reset if the xBox does not come on? AI would not check anything else but would go right to the SSD? Why? AI can't think for itself and uses regurgitated Google stuff :-) Start using your own brain (algorithm). LMBO so weak and predictable.
過去 24時間: 1
過去 7 日: 3
過去 30 日: 16
今までの合計 16
@braydenc what makes you think it is the SSD? What have you checked?
oldturkey03 さんによる
