メインコンテンツにスキップ
モデル番号A1707。 2017年6月に発売されたこのMacBook Proは、最大3.8 GHzのTurbo Boost搭載の最大2.8 GHzクアッドコアIntel Core i7プロセッサーまでのKaby Lakeプロセッサーを搭載しています。
327回答 すべてを表示
My battery still doesn't charge after replacement
Hi,
Recently, my MacBook battery suddenly ceased to charge. I decided to carefully replace the battery.
Initially, my MacBook booted correctly after the battery replacement. However, to my dismay, the following day, the "no charging" problem resurfaced. I am unable to power on my battery (no signs).
Feeling utterly powerless, I'm uncertain about the next steps. Could the problem lie deeper, perhaps within the motherboard?
I appreciate any advice you can offer.
PS 1: Unfortunately, my Mac is unable to boot, preventing me from performing an SMC reset.
PS 2: I've already attempted to use different USB-C ports to troubleshoot the issue.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
Sadly your logic board needs repairs, the Texas Instruments SN650839 Power Management chip needs to be replaced. You can see it in Step 9in the MacBook Pro 15" Touch Bar Teardown which is the same for the 2017 model as well.
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
Thanks for responding. Are you sure that we should replace this chip? I searched for information on it but found almost nothing.
さんによる
@kisac19781 - If you review the schematics and board view drawings testing the power rails voltages you’ll see this often fails.
さんによる
コメントを追加
@kisac19781 you can find it by using the given number, but it's a pain. Use the actual IC description. It is 7X7MM BGA 168 P650839A0B IC. Make sure that you check everything in your PBUS Supply & Battery Charger circuit before replacing one of the most complicated parts :-)
What voltage do you have coming into the board. What does your USB ammeter show? Have you checked PPDCIN_G3H_CHGR? what voltage do you get on there? What voltage do you have on R6921?
There are so many things you should check out before just willy nilly replacing a BGA168 IC. Not saying it isn't but there is no way I would do it without checking the board first.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Timmy さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 53
今までの合計 53
