メインコンテンツにスキップ
GoTab Android Tablet Advice Needed
Hi all, I'm new to electronics repairing world,
I've purchased 10 x GoTab tablets for spares or repair but can't find a guide on your site. As I'm new are these all made in the same factory with different brands Are all android tablets basically the same under the cover?
Thanks for all help?
Update (04/21/24)
Also I'm after what should be done in the situation. Should I assume that a device that won't turn needs a new battery or check the battery with a multimeter. The items have I presume been in storage.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
1件のコメント
I've also noticed that there are some Versus branded tablets. Also looking at the original advert it states you could make two good tablets from three as all parts are interchangeable and should take 15 minutes to make a working tablet
さんによる
コメントを追加
2件の回答
最も参考になった回答
get a usb amp meter it will help determine if the tablets are charging
このアンサーは役に立ちましたか?
スコア 1
7 件のコメント:
Hi apologies for the question what sort of meter should I be looking for
さんによる
Thanks for the suggestion
さんによる
Have ordered the meter and will let you know when it's arrived
さんによる
Hi the meter has arrived . What do I do with it now?
さんによる
2件以上のコメントを表示
コメントを追加
I've been made redundant in my day job and will wating to get a job I will have time to to fully learn how to get know how the USB meter works sand get the original tablets together.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
JimEssex さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 18
今までの合計 128
