メインコンテンツにスキップ
Idylis 70-pint dehumidifier (large size area over 3000 sq ft) featuring direct drain option for continuous use.
1回答 すべてを表示
How do I replace this button?
Basically, I've had this thing for years and years, it's sort of a little ragged, but it still seems to take water out of the air, honestly it got left running during some dusty work and it's never been the same since, the lights for the fan speed have also given up the ghost. but that's not what matters right now.
What matters is the power button is completely obliterated and I'm wondering how difficult it would be to replace it, I'm coveting hack-y solutions because they sure don't give these things away, trashing this thing and purchasing a replacement is eating a big loss
Technically sticking a small object into the hole and poking at the raw button on the PCB kinda-sorta-sometimes works, but it's getting worse if anything, this button's days are numbered.
Also a concern: if I replace this button, how do I seal it from moisture? I feel like it's not a great idea to just drop a different button in and be in the same "Sticking a pencil into the hole" boat.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
Search on ebay because it looks like someone is selling the same top panel containing that set of ‘soft’ buttons.
https://www.ebay.com/itm/124087477604?mk...
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Aeri さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 2
今までの合計 48
