メインコンテンツにスキップ
2013年9月10日に発表されたApple iPhone 5cの修理情報とガイドです。モデル A1532, A1456
1234回答 すべてを表示
Is this logic board from an iPhone 5c to rusty to recover?
I just found my old iPhone 5c and noticed it wasn’t working possibly due to water damage a few years ago. I was able to get the motherboard or logic board out after a little bit of tweaking and I was hoping to get somebody’s insight and knowledged to know if this is too rusty to continue. I was planning on just swapping it out and placing it into another iPhone 5c.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
最も参考になった回答
since it has been sitting for a few years then the corrosion could have caused more damage over time, only way to know is to try it with a good screen, battery and power button
このアンサーは役に立ちましたか?
スコア 1
3 件のコメント:
@coachb6185 before doing that, I would suggest at least cleaning it :-) Pop all the EMI shields off and then use this guide iPhoneの水濡れ・水没ダメージからの復旧方法 and clean your board as described in step 11 and on. It was written for a 3G but all the steps are still pertinent to your board as well.
さんによる
@oldturkey03 you need hot air to remove those shields
さんによる
@tech_ni you are right of course. I'd still feel a lot better to clean it first ;-) @coachb6185 follow the advice given by @tech_ni to work on your board.
さんによる
コメントを追加
回答を追加する
Coach B さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 5
今までの合計 41
