メインコンテンツにスキップ
対象のモデルはA1419 / EMC 2806 / Late 2014 または Mid 2015。 3.3 または 3.5GHz Core i5 または 4.0GHz Core i7 (機種ID iMac15,1)、EMC 2834 late 2015 / 3.3 または 3.5 GHz Core i5 または 4.0 GHz Core i7 (機種ID iMac17,1)のRetina 5Kディスプレイを搭載したすべて。
573回答 すべてを表示
iMac don't start...second LED lights up intermittently every 3 seconds
Hello
Already replaced power supply with the power supply of my other 2012 iMac 27"...and do the same...
Any help to find what is the fault?
Best regards
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
What transpired before you replaced the power supply? Did you alter anything like add memory, replace the CPU…
このアンサーは役に立ちましたか?
スコア 0
9 件のコメント:
Hello
One year ago (more or less), when reassembly CPU on socket (after replace Thermal Past/Thermal Pads), bent 2 pins on socket (but correct this issue), also "split" Fusion Drive (replaced the Apple "Blade" with a OWC 480Gb and SSD SATA Crucial MX500 2TB), upgraded RAM from 8 GB to 32 GB, replaced PRAM battery(BR2032)... and works great for a year...
Some days ago iMac won't start...I changed the power supply because it didn't start...but don't solved the issue...
Could this be related to the issue of socket bent pins ? (a year ago)
さんによる
@boxerboss - Sadly yes 😡 the bent pins are weaker and over time fail. You could try reseating the SO-DIMMs. Do you have an external bootable drive to double check if the current boot drive is messed up. But I’m leaning the socket is the issue.
さんによる
Hello
I already removed RAM and put it back in...issue persists
Do you mean to try with a USB bootable Big Sur?(the macOs installed)...and try to start in Recovery Mode?...or Safe Mode ?
さんによる
@boxerboss - I just find having a bootable external drive is quicker to just boot up from. You can also try booting up under anyone of the Startup options, do any respond?
さんによる
Can I create a "bootable external drive" for my iMac in other Mac?
さんによる
4件以上のコメントを表示
コメントを追加
回答を追加する
JOAQUIM LOPES RAMALHOSA さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 52
今までの合計 52
