Replaced HDD but still getting disk full warning
I successfully replaced my iMac's HD (250GB => 2TB).
Followed all recommendations and had my computer back running from last TimeMachine backup (Mac OS X Lion).
Unfortunately, I am now getting "Disk Full" warning at all times. This didn't happen at first.
Tried Disk Repair, which doesn't find anything to repair.
Any leads?
Cheers,
Joel
この質問は役に立ちましたか?
1件のコメント
You, if you're doing lots of video, audio or photo files, some application, or someone, could be writing information to your disk.
In Finder click on the HD image and do Command-I (OR right click select get info) it may take a minute but you should see in the popup window that opens just above the label boxes Capacity:XXX, Available:XXX and Used:xxx
If the drive is indeed full or near full you must determine where the space is going. If it's not full you have a different issue.
From Finder in List View, go to Menu->View-> Show View Options and click "calculate all sizes" (this will take a while) ''and then click the sort by size column so that it will list the largest folder first. What is that folder?
originalmachead さんによる
