メインコンテンツにスキップ
My phone touch not work
My phone touch is not work
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
Your phone must be internally damaged or is lagging due to repeated usage or clicking on the screen multiple times in one sitting.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
@luckygaikhwad first start your Tecno in safe mode. Use something like this video to get into safe mode. If your touch screen works in safe mode, you know it is a third party app that is causing this. You will have to delete those apps. If it does not work in safe mode either, you may have a bad touchscreen. Time to replace the display assembly.
Since iFixit does not yet have a guide for this, use something like this video to replace it. Replacement screens are readily available at many online stores.
While you work on your phone, take lots of pictures. Once you are done with it, take those pictures and create a guide for iFixit. That will help the next person that has a device with the same issues as you do. It's easy and fun to create these guides. https://ifixit.com/Guide/new The iFixit community will appreciate this.
Repair is War on Entropy!
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
in order to start in safe mode you need a working touch screen...
さんによる
コメントを追加
回答を追加する
Lucky Gaikhwad さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 13
今までの合計 155
