メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
2022年2月に発売されたSamsungのスマートフォン「S22 Ultra」の修理・分解情報。
network is very slow or almost no coverage after dropping the phone
My phone fell since then and I have only had problems with network and range. Some places not much and sometimes not at all, someone can help me where the problem may be so that I can solve it
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 3
2 件のコメント:
Network reng problem my phone samsung s22 ultra
さんによる
مشاكل في اتصالك بالشبكة.
さんによる
コメントを追加
2件の回答
It seems like dropping your phone may have caused issues with your network connectivity. Here's a brief guide:
  1. Check for physical damage:
    • Dropping your phone could have damaged its internal components, including the antenna or network receiver.
    • Inspect the phone for any visible damage, such as cracks or dents.
  2. Restart your phone:
    • Sometimes, a simple restart can resolve temporary network issues.
    • Power off your phone, wait a few seconds, then power it back on to see if the network connectivity improves.
  3. Reset network settings:
    • If restarting doesn't help, try resetting your phone's network settings.
    • This will remove saved Wi-Fi networks, Bluetooth connections, and cellular settings, so you'll need to re-enter them.
    • Look for "Reset Network Settings" in your phone's settings menu.
  4. Update software:
    • Ensure your phone's operating system is up to date.
    • Manufacturers often release software updates to fix bugs and improve performance, including network connectivity.
By following these steps, you can troubleshoot and potentially resolve the network connectivity issues caused by dropping your phone.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
@tabathakang Blah, Blah, Blah ¯\_(ツ)_/¯ "Nobody's listening to me
Nobody's listening"
Like before. Can the OP fix the device with your Answer? Nope! Your AI is weak
さんによる
コメントを追加
olha isso é um problema dessa geração de celulares pós 5g...
infelizmente não é de facil reparo, dependendo da engenharia aplicada no wardware nem tem reparo, devo ter uns 5 dispositivos de direntes modelos e marcas com problema de conectividade semelhantes após quedas, eu indicaria a voce uma assitencia autorizada para que eles troquem a placa inteira.
especificamente esses aparelhos são bem chatos quando dão esse problema ( que geralmenete so piora quando o dispositivo funciona a maios termos ) .
meus pesames mas pela minh aexperiencia e so outra placa ou algum mago do hardware pra substituir metade dos chips do systema de rede.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Mertcan dincer さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 7
過去 30 日: 42
今までの合計 613
