set of physical controls to the right rear Panasonic fx750b
This controls start working by it self without any reason. Sometimes volume up or down.
Hi @arkadiuszw84862,
Check if the auto gain setting is enabled in the Sound settings. If so try disabling it and check if this resolves the problem
Go to Menu → Sound → Auto Gain Control and select Off
Have you verified that it is the TV Vol Up/Down button that is the problem and not the TV remote by removing the batteries from the remote control?
このアンサーは役に立ちましたか?
When the rear buttons start working by it self I see the graphics on my screen
So you're saying that the TV turns on by itself, is this correct?
If so have you checked for any Timer settings that may turn the TV on and off?
Here's the user guide that may help.
過去 24時間: 0
過去 7 日: 2
過去 30 日: 19
今までの合計 19
