Led bulb 120wt repair
Led light bulb 💡 repair
@hamzajutt you're really not giving us much to work with. It would be nice if you would at least tell us what your bulb does, what happened to it and what you have already checked.
Here is a generic answer. Take a look at this teardown LED Light Bulb Teardown It will show you how to get into one of those and this one LED Birne Lampe 230V E27 defekt reparieren will show you how to check and possibly repair the bulb. You need to check the LED's, the capacitors as well as the LED driver. Let us know if you need more assistance with that and you can always post images of your bulb components and circuit board with your question. iFixitでの質問に画像を追加する方法
ガイド
難易度:
とても簡単
2 - 5 minutes
ガイド
難易度:
中レベル
30 minutes
ガイド
難易度:
中レベル
このアンサーは役に立ちましたか?
過去 24時間: 1
過去 7 日: 13
過去 30 日: 82
今までの合計 486
Charging LED bulb repair
Satya Narayan sahoo さんによる
Yes my led bulb is dead
Ashvini Vaidya さんによる
