メインコンテンツにスキップ
The Samsung Galaxy A14 5G is an android smartphone developed by Samsung Electronics. It was released in January 2023.
20回答 すべてを表示
My phone is not charging after screen replacement
Hlo,
My Galaxy A14 5g was charging normally before replacing the screen but after screen replacement I'm having the charging issue it's isn't charging . I wanna ask is it's any capacitor got short so that's why current isn't passing or it isn't charging that maybe the screen strip which connects to charging board could be damaged. Is their is any possibility and tge possibilities i told you is it can be?
Thank you
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
ベストアンサー
@muhammadbi17208 anything is possible. The very first thing you want to do is to double check your work. The A series has issues with the flex cables coming from the charging board to the main board. Check that for micro tears and corrosion and proper connection to the boards. After that it's the charging board and flex cables. After that get a USB ammeter and see how many amps your phone pulls from the charger, if any. Measure the voltage on the battery connector to determine if your voltage increases when you plug your phone in. Let us know what you find out.
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
Thanks a lot today i gone for repairing my mobile and the problem was in flex cable which was connected with charging board and the he replaced it and now my phone is charging and working as before
さんによる
コメントを追加
回答を追加する
Muhammad Bilal さん、ありがとうございました!
統計データ:
過去 24時間: 3
過去 7 日: 19
過去 30 日: 42
今までの合計 432
