メインコンテンツにスキップ
2019年4月にHuaweiより発売された新モデルスマートフォンです。6.47" FHD+ OLEDスクリーン、ディスプレイ内に搭載された指紋センサ、40MPメインカメラに加えて、8MP望遠カメラと新イヤホンスピーカーテクノロジーを搭載しています。モデル番号はVOG-L29とVOG-L09です。
53回答 すべてを表示
What is the cause for flashlight being greyed out, main camera glitchy
Flashlight is greyed out and cannot be accessed (Leads me to think it is ribbon connector related)
Additionally the main camera does not work, and apps say Error with camera etc each app warns uniquely that it cannot connect.
Sometimes after a reboot, like 30% of the time, camera can activate, however main camera cannot focus. Wide and tele seem fine.
So what seems to be the issue based on above?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
最も参考になった回答
This usually happens when I part such as a camera has been swapped in the phone and isn't an OEM part and will throw similar codes and issues that you're having, this is usually the case with iPhones, also I have seen this happen to phones that were dropped even though no physical damage on the outside it would break cameras on the inside.
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
The phone has original parts and has never been opened, it was working perfectly fine before it gave issues.
さんによる
コメントを追加
Exact issue with mate 30 pro. The main camera in both P30 pro and mate 30 pro has a $@$*!& focus mechanism which almost always breaks after some years. It seems to me that it's the fault of the focus mechanism, but I'm no expert. In all cases, replacing the camera module fixes the problem
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
ItsDave さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 4
過去 30 日: 14
今までの合計 47
