The Craftsman Walk Behind Mower 917.378481 is a gasoline-powered lawnmower with a 6.75 HP Briggs & Stratton 4-cycle engine and a 1.6-quart fuel capacity. This page provides information on its features such as its 21-inch steel blade, variable speed rear wheel drive, 7-position height adjustment, mulching ability, and compatibility with a rear bag grass catcher.
Are you talking about the plastic drive belt cover on top of the mower deck with one bolt right about in the middle of it? Here's a link to an exploded view .
I believe that if you push on the front of this cover while gently lifting, a tab will release at the front of the cover and you should be able to lift it off. It appears there are two tabs at the rear of the cover that should slide out once the front tab is released.
https://www.ereplacementparts.com/crafts...
moe_r さんによる
yeah, i got the bolt out but didn't want to break any tabs off by pulling it too hard. do you just pop it off.
BLAIR SCHIMMING さんによる
moe_r さんによる
