メインコンテンツにスキップ
Microsoftの次世代4kゲームコンソールのXbox Series Xです。Xbox Series Xは対応コンソールと共に2020年11月10日に発売されました。
What part of the xbox series x handles wireless controller connecdion?
what part of the xbox series x handles wireless controller and headset connection? My Xbox Series X keeps disconnecting my controllers and headsets. I've tried every single suggested fix I could find. The only thing I can think of now is putting a new part in it. I just don't know what the official part is or how to get it.
Would it be better to take it to a repair place? I don't have much money so I thought buying the part and repairing it myself might be better. Although I've never repaired one before.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
ベストアンサー
Hi!
Sounds like your bluetooth chip died and need to be replaced.
It’s located on the Accessory Antenna Board.
Here is the guide to replace it: Xbox Series X アクセサリアンテナボードの交換
It’s not that easy to replace it if you don’t have any experience yet. Please check out the guide, here you can determine if you are confident to replace it by yourself or bring it to a repair shop!
You could buy the part here: https://a.co/d/5U8xs9h
このアンサーは役に立ちましたか?
スコア 1
4 件のコメント:
Awesome, thanks for the help! I'll get back to you when I have either fixed it myself or went to a repair place. I'll probably buy the part myself either way though 😆.
さんによる
My pleasure :D! Alright, just let us know if you've fixed it or not (and when it's fixed). If you are going to repair it by yourself, good luck! No soldering is required, so this makes the repair somewhat easier :).
さんによる
So, I finally put in a "new" Accessory Antenna Board. It worked...for a day. It's once again disconnecting my controller and headset. I guess I'll have to get a whole new console. Unless you guys have some other trick up your sleeve😅. The "new" board looked used, it had the Microsoft logo scratched off and some stickers missing, also some wear. I understand it was probably refurbished, but what if that's the problem. What if I need an actually new board, not refurbished.
さんによる
Hi Karman! Hmm... Since it worked for a day, does say something about the Antenna board. It's possible that the Antenna board is having the same issue as your old one had. I would try to get a replacement again, to see if that will fix it...
さんによる
コメントを追加
回答を追加する
Karman Wilmot さん、ありがとうございました!
統計データ:
過去 24時間: 3
過去 7 日: 16
過去 30 日: 61
今までの合計 376
