メインコンテンツにスキップ
Xbox 360は、2005年11月22日に発売されたMicrosoft製第二世代ゲームコンソールです。
How do I fix my 360 it says unrecognized disc
everytime i put in a game it says open tray or unrecognized discive cleaned it very well cleaned the lense jus wont work sounds like it wants to but wont
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 13
1件のコメント
ive dione that with a brand new ganme an it keeps spinning
will not read it
さんによる
コメントを追加
3件の回答
ベストアンサー
unfortunately there is no simple solution :(
1. Open your Xbox and CD drive. Clean all optical elements on it.
2. If it did not help find 2 small potentiometers and try to increase voltage on the laser.
3. Replace your cd drive - but you need to reflash a new one with the old cd key.
If you don't understand how it works it will be much better to go to any repair shop - I don't know how much it costs in the US but in London its about 20 quid (just the labour)
Peter
このアンサーは役に立ちましたか?
スコア 8
4 件のコメント:
+1 Piotr, good answer. kanoa, start off with the easy and inexpensive stuff, clean your laser. You can use a cleaning DVD for that, they are available at most department stores.
さんによる
ccccccyuigfddfghjkl;lkjh
さんによる
I did this like 2 months ago and my Xbox 360 works like brand new
さんによる
But it is not working again now, why?
さんによる
コメントを追加
there IS a simple solution. You'll have to open the DVD drive, and replace the laser with an identical one. you can replace the entire "sled" assembly. but the DVD logic board MUST stay with the xbox's motherboard. (unless you have away to flash the board)
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
We can clean the disc when its recognized disc. All we do is toothpaste and will leave in five mins.Then wash it to see it works.
このアンサーは役に立ちましたか?
スコア -1
4 件のコメント:
After u put the toothpaste in the game how do u grt it off. Wipe it run water over it or what.
さんによる
I think that toothpaste can destroy the disk
さんによる
yes it can do not try that
さんによる
Hand sanitizer I use then runic under water and wipe with toilet roll as its softer than kitchen roll
さんによる
コメントを追加
回答を追加する
kanoa さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 9
過去 30 日: 41
今までの合計 47,943
