メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
9月9日に発売されたApple最小のiPhone 14は、6.1インチの有機ELディスプレイ、進化したデュアル12MPカメラシステム、オートフォーカス付きフロントカメラを搭載しています。iPhone 13の後継モデルです。
My iPhone 14 Is restarting every 3 minutes After It fell in water
PLEASE HELP ME!
Restarting every 3 minutes, i checked the panic log and found "sensor array 0-4 is 0x0, 0x400000, 0x0, 0x0, 0x0". So i replaced the wireless charging Flex with a new one but nothing changed. What am I supposed to do now?
Aggiorna (04/09/24)
Here It Is part of the panic log
incident" : "6421DE41-DE57-4DBE-99F0-C5610EC43463",
"crashReporterKey" : "884233b2e31aa549398edeeb4a798e3d6efab935",
"kernel" : "Darwin Kernel Version 22.6.0: Wed Jun 28 20:52:14 PDT 2023; root:xnu-8796.142.1~1\/RELEASE_ARM64_T8110",
"date" : "2024-04-09 20:55:42.50 +0200",
"panicString" : "panic(cpu 2 caller 0xfffffff0201364ac): SMC PANIC - ASSERTION FAILED: target\/d27\/target.cpp:266: 0, SMC BSC failure, spreadsheet ver(*10) 40\nS.sensor array 0 - 4 is 0x0, 0x400000, 0x0, 0x0, 0x0 \nF.sensor array 0 is 0x0\n\n - Misc(2) OUTBOX1 not ready\nASSERTION FAILED: target\/d27\/target.cpp:266: 0, SMC BSC failure, spreadsheet ver(*10) 40\nS.sensor array 0 - 4 is 0x0, 0x400000, 0x0, 0x0, 0x0 \nF.sensor array 0 is 0x0\n\n\nRTKit: RTKit-2062.142.1.release - Client: AppleSMCFirmware-3424.140.21.0.4.d27.REL\n!UUID: 2d1a421e-cd24-3eaf-a935-3186cf73b348\nTime: 0x000000010da1bbda\n\nFaulting task 2 Call Stack: 0x00000000000486cc 0x00000000000480a0 0x0000000000047eb0 0x000000000004a5d8 0x0000000000003f8c 0x000000000001eb10 0x000000000002155c 0x00000000000366c8 000000000000000000\n\nChinook ASC Async error info: \nl2c_err_sts 0x5000fbfc00000000, l2c_err_adr 000000000000000000, l2c_err_inf 000000000000000000\nlsu_err_sts 000000000000000000, fed_err_sts 000000000000000000, mmu_err_sts 000000000000000000\ndpc_err_sts 000000000000000000\n\nMailbox (0): (0)\n Inbox AKF_KIC_INBOX_CTRL = 0x00020001, AKF_KIC_MAILBOX_SET = 0x11111101\n Outbox AKF_AP_OUTBOX_CTRL = 0x00020001, AKF_AP_MAILBOX_SET = 0x00000000\n\n dir endpoint timestamp msg\n ==== ============ ================== ==================\n
[RX]
EDIT: I took my phone to a repairing shop and they told me they fixed my motherboard (completely losting my data) for 230€… unfortunately that was my only option to have my phone back to life🥲
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 2
コメントを追加
2件の回答
最も参考になった回答
Sadly in terms of water damage there is not much you can do besides just buying a new phone
The only thing I can really make out from this is that your wireless charger is shot
If anyone knows what sensor 0-4 is or what error 0x0 is then we might have the ability to fix it
このアンサーは役に立ちましたか?
スコア 1
5 件のコメント:
I alredy replaced the wireless charging flex and tried the torch (which is connected to that flex cable) and it works, so i think that's not the problem...
さんによる
@peppemariani again that error message is huge and I'm no expert in it so it could be fixable but with water damage that causes a shutdown it PROBABLY won't be fixable
さんによる
Also it lookes like the SIM card reader is cooked
さんによる
@hampter no that was out of the case ahaha
さんによる
ah that would explain it
さんによる
コメントを追加
Actually, it might have been defective press connectors that connect the various components to the motherboard, rather than the motherboard itself. The iPhone 14 would shut down every three minutes if something's not connected, so the problem might be corroded press connectors on the motherboard. I once thought my 14 had a motherboard issue when I was replacing a shattered rear glass panel(it also kept restarting when I didn't connect a rear glass panel), but later when the replacement was installed, it stayed on without shutting down randomly.
Also, you mentioned that your SIM card reader was 'outside the case', so that might have been the problem.
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
So the repair shop charged me 230€ (saying that it was for the motherboard replacemente) for some flex disconnected or corroded?
さんによる
I don't think the repair shop would do that, since there's no way your motherboard could be reused again with your Apple ID on it. Maybe the motherboard itself was corroded, since it had two layers and water might have messed up the contacts between the two layers. In that case only very complex microsoldering can save it, and not every repair shop can offer that.
The repair shop must have its reason for a motherboard replacement though. They could have separated the two layers and decided that it can't be fixed)
さんによる
コメントを追加
回答を追加する
Peppe Mariani さん、ありがとうございました!
統計データ:
過去 24時間: 5
過去 7 日: 19
過去 30 日: 84
今までの合計 2,150
