هل يمكن تحويل بت 32 إلى بت64 Can 32 bits be converted to 64 bits?
و كيف يتم ذالك
And how is this done?
Hi @alihmt
If your laptop is a Samsung NP-N102S-B05PH then you can install a 64-bit Operating System as the both the CPU (Intel Atom 2100) and the chipset (Intel NM10) support it.
Problem is that it only supports a maximum of 2GB of memory so this will limit the performance in any case whether it is 32-bit or 64-bit.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 1
過去 30 日: 20
今までの合計 20
