メインコンテンツにスキップ
初代Xboxは、Microsoftで初めて広く普及したビデオゲームコンソールです。上面と前面に「XBOX」の文字が入った黒いケースで、簡単に識別できます。修理は一般的な工具で簡単にできます。
170回答 すべてを表示
Power supply flashes red and green, then reset button pops out
Recently, my xbox power cable (the one with the RESET and TEST buttons) has not been cooperating with me. I do the safety method every time I use it (press TEST, RESET button should pop out, then press RESET), but recently whenever I press in the RESET button, the indicator light flashes between red and green for a bit, and then the RESET button pops back up. How do I fix this?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
最も参考になった回答
So either the gfi brick (power cord) has ceased being able to do it's job or (and this is equally likely/possible) it's doing it's job correctly and your actual power supply has developed a dead short. The version 1.0 xbox had a Foxcon power supply which had a design oversight/flaw. The solder joints on the power port could break and cause a dead short which in turn "could" cause a fire. So xbox release free of charge to all customers that GFI enable power cord. It's job is to trip and cut power if it detects a short in the power supply, this is to prevent a possible fire.
This is a potentially serious matter for which there isn't likely an "easy" fix. If you want you could try a different "known working" gfi power cord. If it still happens then the fault will definitely be the internal power supply. That would be the easiest place to start. I strongly advise against messing with the internals of either the gfi or the consoles power supply unless you know what you are doing/dealing with.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Lappy4861 さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 14
今までの合計 14
