My hinge broke on my tuf gaming f15 fx507zc
it's like the screen is pulling the case apart. Whenever I open it the motherboard bends unless I push it together.
@leventecsaki looks like it may have cracked the bottom case. Kind of hard to tell. Time to replace those. Since iFixit does not yet have a guide for this try something like this video different model but identical case.Not great but it'll help to get there. you can find the hinges by doing an online search at many online stores. The case will be more difficult and may require some epoxy repair :-) you an of course post some pictures of any damaged parts with your question. That way we can see what you see and hopefully help you further. iFixitでの質問に画像を追加する方法
While you work on your laptop, take lots of pictures. Once you are done with it, take those pictures and create a guide for iFixit. That will help the next person that has a device with the same issues as you do. It's easy and fun to create these guides. https://ifixit.com/Guide/new The iFixit community will appreciate this.
Repair is War on Entropy!
このアンサーは役に立ちましたか?
If the right hinge is broken and not just loose, search online for 13NR09M0M09021 to find hinge suppliers that suit you bets.
The above number is the Asus part number for the right hinge in your model laptop.
We just had this problem too, son's computer, found that of the 6 tiny screws that hold bottom case in place, 3 had fallen out, right on that same corner as original poster. Completely missing. Possibly because the computer runs so hot, the screw coating fails and they just loosen and fall out over time? We took a screw from other side and secured the corner, solved, but now looking for additional replacement screws.
このアンサーは役に立ちましたか?
過去 24時間: 2
過去 7 日: 12
過去 30 日: 59
今までの合計 84
