My remote stopped working can it be fixed
I changed the battery didn't work also in the morning it worked but in the afternoon it didn't
Try using some WD40 contact cleaner on the buttons. Remove the batteries first and then spay the cleaner on all the buttons and then press all the buttons a few times so the cleaner seeps in. Put new batteries in the remote and then retry. Do not use the normal WD40 it has to be (WD 40 contact cleaner)
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 1
過去 30 日: 18
今までの合計 18
Lawrence, not much we're going to be able to do to help without knowing just what it is you've got there. What does the remote control? Is this a factory or aftermarket remote? Is it RF or IR (radio or infrared)?
Jerry Wheeler さんによる
