メインコンテンツにスキップ
Repair guides and support for your Toshiba TV.
20回答 すべてを表示
dim light and No picture on the display
I have a Toshiba TV 55 inch And everything on it works completely fine and it’s just showing me a dim light and No picture on the display this is my TV model (55LF621U19) please help i bought a new Motherboard and Power board and ribbon cable But nothing is working help me
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
1件のコメント
Hey, you remember me up to know I can’t find a part anywhere and before you tell me eBay in those places again, they don’t have it
さんによる
コメントを追加
1 件の回答
最も参考になった回答
@jaygamer1 that sure sounds like a failed backlight array. Turn your TV on and use a flashlight and shine the beam at an angle against the screen. Do that in a darkened room. See if you can make out shadows or shapes or even the Toshiba splash screen. If you do, then it is your backlight that has failed.
Your TV uses 8 Backlight strips and are available for a cost of around $USD60 Not a terribly complicated job but you do have to disassemble your complete panel. Let us know what you find out when you do this.
Update (04/03/24)
@jaygamer1 awesome. Since you have sound and the backlight, you can try a new T-con board (if it has a dedicated one) or a Tape-off. Something like shown on here
このアンサーは役に立ちましたか?
スコア 1
9 件のコメント:
It’s not the backlight all my back lights are working completely fine
さんによる
This TV models don’t have a T-con board And what is the tape-off plsss help
さんによる
さんによる
@jaygamer1 correct. That is why I suggested aTape-off. Give it a try and it does work probably 3/4 of the time
さんによる
さんによる
4件以上のコメントを表示
コメントを追加
回答を追加する
jaygamer 1 さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 130
