メインコンテンツにスキップ
ATX Mid Towers have the same general build and parts as other mid size computer towers
Message every time the PC is turned on
Hi, every time I turn on the PC this message appears "Please enter setup to recover Bios setting.
When Raid configuration was bulit,ensure to set SATA configuration to RAID mode.
Press F1 to run SETUP."
What should I do to solve this problem every time I start the PC?
Update (04/11/24)
Solved I changed the bios battery and solved the problem.
Thanks for the reply.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
1件のコメント
Hi @ale60137,
What is the make and model number of the PC or the motherboard if a custom build?
Was the PC setup to be used in a RAID configuration or not, before this problem occurred and if so was it working OK?
Was there any general power failures to the premises where the PC is located, when the PC was turned on and working, just before the problem occurred?
さんによる
コメントを追加
1 件の回答
ベストアンサー
Check BIOS battery, it needs to be at least 3.6
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
ale さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 5
今までの合計 189
