What thickness of tape should I use for the back glass?
I just bought the 1mm tape and I’m wondering if that is going to be thick enough to hold the back glass together?
@mikedel the "1mm tape" is a bit confusing. Your P30 Pro use an adhesive across the whole back cover with the cutouts for the cameras, NFC antenna etc. You can get those from plenty of online stores. If nothing else, check this guide カスタム加工された両面テープの装着方法 on how to do it if you just have the adhesive itself.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 3
今までの合計 11
