Purana mobile ka battery fast drain kaaran aur upay Battery fast drain
Translation Hindi - English
Battery fast drain of old mobile, causes and solutions
@ipslcd35582 Why is based on the effect that aging has on a Lithium-ion battery. The internal resistance increases and "waste" power which it then converts to heat. As the internal resistance increases it converts more power to heat and loses its capacity. Since voltage also drops as the battery discharges, the increased resistance causes it to reach cutoff voltage earlier and reduces the effective capacity. There is a whole lot written about this. Best place to start is on here This Faraday Insights 10 Web FINAL explains all of this in far more detail then we could do on here.
Solution - replace the battery. Since ifixit does not yet have a guide for this, Use something like this video Replacement batteries are readily available at many online stores.
While you work on your phone, take lots of pictures. Once you are done with it, take those pictures and create a guide for iFixit. That will help the next person that has a device with the same issues as you do. It's easy and fun to create these guides. https://ifixit.com/Guide/new The iFixit community will appreciate this.
Repair is War on Entropy!
Translation
@ipslchd35582 kyon umr badhane ka lithiyam-aayan baitaree par padane vaale prabhaav par aadhaarit hai. aantarik pratirodh badh jaata hai aur shakti "barbaad" ho jaatee hai jise baad mein garmee mein badal diya jaata hai. jaise-jaise aantarik pratirodh badhata hai yah adhik shakti ko ooshma mein parivartit karata hai aur apanee kshamata kho deta hai. choonki baitaree dischaarj hone par voltej bhee girata hai, badhe hue pratirodh ke kaaran yah katoph voltej tak pahale pahunch jaata hai aur prabhaavee kshamata kam ho jaatee hai. isake baare mein bahut kuchh likha gaya hai. shuroo karane ke lie sabase achchhee jagah hai yahaan yah Faraday Insights 10 Web FINAL is sab ko kaheen adhik vistaar se bataata hai ham yahaan par kar sakate hain.
samaadhaan - baitaree badalen. choonki aaeephiksit ke paas isake lie abhee tak koee gaid nahin hai, isalie is veediyo kee tarah kuchh ka upayog karen riplesament baitariyaan kaee onalain stor par aasaanee se upalabdh hain.
jab aap apane phon par kaam karen to dher saaree tasveeren len. ek baar jab aap yah kaam poora kar len, to ve tasveeren len aur ifixit ke lie ek gaid banaen. isase agale vyakti ko madad milegee jisake paas aapake jaisee hee samasya vaala upakaran hai. in gaidon ko banaana aasaan aur mazedaar hai. https://ifixit.com/Guide/new ifixit samudaay isakee saraahana karega.
marammat entropee par yuddh hai!
@ipslcd35582 क्यों उम्र बढ़ने का लिथियम-आयन बैटरी पर पड़ने वाले प्रभाव पर आधारित है। आंतरिक प्रतिरोध बढ़ जाता है और शक्ति "बर्बाद" हो जाती है जिसे बाद में गर्मी में बदल दिया जाता है। जैसे-जैसे आंतरिक प्रतिरोध बढ़ता है यह अधिक शक्ति को ऊष्मा में परिवर्तित करता है और अपनी क्षमता खो देता है। चूंकि बैटरी डिस्चार्ज होने पर वोल्टेज भी गिरता है, बढ़े हुए प्रतिरोध के कारण यह कटऑफ वोल्टेज तक पहले पहुंच जाता है और प्रभावी क्षमता कम हो जाती है। इसके बारे में बहुत कुछ लिखा गया है। शुरू करने के लिए सबसे अच्छी जगह है यहां यह Faraday Insights 10 Web FINAL इस सब को कहीं अधिक विस्तार से बताता है हम यहां पर कर सकते हैं.
समाधान - बैटरी बदलें. चूंकि आईफिक्सिट के पास इसके लिए अभी तक कोई गाइड नहीं है, इसलिए इस वीडियो की तरह कुछ का उपयोग करें रिप्लेसमेंट बैटरियां कई ऑनलाइन स्टोर पर आसानी से उपलब्ध हैं।
जब आप अपने फोन पर काम करें तो ढेर सारी तस्वीरें लें। एक बार जब आप यह काम पूरा कर लें, तो वे तस्वीरें लें और iFixit के लिए एक गाइड बनाएं। इससे अगले व्यक्ति को मदद मिलेगी जिसके पास आपके जैसी ही समस्या वाला उपकरण है। इन गाइडों को बनाना आसान और मज़ेदार है। https://ifixit.com/Guide/new iFixit समुदाय इसकी सराहना करेगा।
मरम्मत एन्ट्रॉपी पर युद्ध है!
このアンサーは役に立ちましたか?
過去 24時間: 3
過去 7 日: 15
過去 30 日: 106
今までの合計 123
