メインコンテンツにスキップ
PS3スリムは、オリジナルの型番CECH-2000を持つPS3ビデオゲーム機のセカンドバージョンである。ソニー・コンピュータエンタテインメントによって製造され、初代プレイステーション3の多くの問題を修正した。2009年9月1日に発売された。
465回答 すべてを表示
Playstation 3 slim no screen nor audio appears.
I tried to turn on my console but it didn’t work, i tried entering safe mode but it just powers off. The Power Supply makes some kind of “tick” sound after it turns off. I opened it but the motherboard was okay. So i replaced the HDD and nothing happened. So i didn't put the hdd in the ps3 but still nothing happened. I replaced the power supply snd still has the same issue. I took it to the repair shop and they said they dont know what’s happening to it.
My guess is the video chip or the HDMI is damaged.
Information:
PS3 Slim CECH:2001B
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
Have you tried booting it with the disk drive disconnected? Sometimes...that tick sound is the laser returning home because of a boot failure. When the console is plugged in does the red standby light come on and stay on, or no?
There are so many possibilities, trying to nail down the culprit could be "difficult". Did the repair shop do a Syscon read, or even attempt one? Even if it were HDMI or associated components the repair shop should've been able to tell you so, that type of issue is typical/routine stuff.
このアンサーは役に立ちましたか?
スコア 0
6 件のコメント:
I booted it with the disk drive disconnected but it did not work.
さんによる
And the red light stays on
さんによる
@osmankhwaja With the disk drive disconnected did it still make the "click" sound?
さんによる
Yes. Im guessing its the psu
さんによる
@osmankhwaja Indeed but if you already replaced the psu, that click might be the psu "saving" itself from a faulty motherboard by shutting down.
https://www.youtube.com/watch?v=aMW4xFaw...
That guy discovered multiple faults causing your same symptom. The cause of instant power off after pressing the power button doesn't always stem from the same one issue. It can be any of many components. Sometimes you get lucky though and really is just a bad psu. Good luck.
さんによる
1以上のコメントを表示
コメントを追加
回答を追加する
Osman Khwaja さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 2
今までの合計 20
