メインコンテンツにスキップ
2014年9月19日に発売されました。この5.5インチサイズのスクリーンをもつiPhoneは、iPhone6の拡大サイズ版です。
1526回答 すべてを表示
Battery replaced and I’m scared of the old one
Old battery scares me more than being in Iraq. There’s a sickly sweet smell coming from it. Tried to seal it away in the replacement box and a bag. I really want to call the fire department for real.
What else can I do? How long do these things de-gas for? I’ve never seen a battery do this with out igniting.
Yes I tried the pull tabs they failed because of the battery damaging itself way before I opened the phone. (Apparently years ago.)
Yes I used 99% IPA to breakdown the glue strips.
No the battery is not becoming a spicy pillow.
No the battery is not warm to touch with or with out gloves.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 2
コメントを追加
2件の回答
最も参考になった回答
I remember I accidently punctured a battery once.
What I did was to simply place the battery in a bowl of salty water and then leave it for a couple hours (or until the water stops bubbling). I would also recommend doing this outside as it does release hydrogen and chlorine which can prove to be a hazard if the area is not well ventilated. This should discharge the battery and make it safer to handle.
このアンサーは役に立ちましたか?
スコア 1
6 件のコメント:
I didn’t have the chance to puncture it lol. I used the guitar pick to get it out.
さんによる
This method should still work considering all it does is discharge the battery via electrolysis, which is some interesting chemistry stuff.
さんによる
@mapleinit appreciate it 👍
さんによる
@youweesh No problem!
さんによる
@mapleinit Water? Lithium and water do not like each other at all. Might just create a bit of an explosive gas (Lithium Hydroxide and Hydrogen)
さんによる
1以上のコメントを表示
コメントを追加
@youweesh if you are really concerned about it do what I do. Stick it in a metal can filled with sand. Let it de-gas for a day or two. After that dispose of it according to your local regulations.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
You Weesh さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 7
今までの合計 60
