Power supply keeps blowing capacitors
My ps4 pro blew a capacitor in the power supply(450v-150uf) I replaced it with one exactly like it, it worked fine for about ten minutes then it blew the cap right next to the one I had replaced (450v-100uf) so I replaced that one,and same thing,lasted about ten minutes,obviously something is causing the caps to go out.i just want to know if the problem is in the power supply so I can just replace the entire power supply, if the cause is do to something outside of the power supply then there's no sense in replacing it with a new one,any ideas would be greatly appreciated.
この質問は役に立ちましたか?
