メインコンテンツにスキップ
Repair and disassembly information for HP 15s Laptop PCs, specifically 15-dw models. The HP 15-dw is a lightweight and portable, mid-range laptop series designed for everyday use, featuring 15.6-inch displays, 11th generation Intel processors, DDR4 memory, and SSD storage. Identified by model numbers starting with 15-dw or 15s-dy.
2回答 すべてを表示
Battery replacement 15-dw3021nia S/N CND04651YZ
I found 2 models HT03XL which is the original replacement of my battery, and also an exact similar model TF03XL. the later seemed to be with higher voltage 11.55v, higher capacity, and 33% cheaper above that... looks like a battery with more advanced cells, and I want it instead of my same old battery, but I am not sure if it is compatible. on HP site there was a couple BIOS updates to support new battery models, but they didn't list what are these new models. is this battery TF03XL compatible with my laptop?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
From what I can tell it is not compatible, unfortunately.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Packet Loss Gamer さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 12
今までの合計 31
