Where is the power steering pump?
Hello! lately when I turn the steering wheel the pump makes more and more noise. The hydraulic steering liquid level is ok, so I think I need to replace the power steering pump. But I've seen there's different pumps depending if the van has climate control system or just A/C, also depends on the gearbox (manual / automatic) so I think the best I can do is to find the power steering pump, check the OEM reference and then replace it, what do you think? Where can I find it? Thank you
@ruben88453 help us to help you. what year and what exact model is your Transporter? Does it have AC or climate control? Consider opening the hood and taken a couple pictures from the top and a few from the bottom. Post those with your Question. Let's see if we can figure this all out. iFixitでの質問に画像を追加する方法
The PS pump is on the passenger side on the bottom of the engine. Yes, you will need to remove the AC compressor.
oldturkey03 さんによる
